I tried many ways to find the answer to my question, but I failed to locate one. I believe I had asked a similar question a while back, but I have no luck finding it.
I replaced my clutch slave cylinder on my 85 Spider. I let the fluid gravity drip for a few minutes from the slave cylinder bleeder. Then I had an assistant push the clutch pedal down and hold it while I opened the bleeder. Then I closed it and my assistant let the pedal return (which it did fine). We did that many times but I am noticing when he holds the pedal down, the clutch fork slowly pushes the slave cylinder rod back into the slave cylinder. This is while the bleeder is still closed, before I open it to bleed it. I do not see any drips or leaks anywhere.
The question: is the slave cylinder supposed to do that until I bleed all the air out, or am I having an issue I need to contend with before I spend the day (and a 12 pack) under the car trying to bleed it for no reason?
I ask a lot on here, and I truly appreciate the help. I will be under the cat finishing off the beer while I await for responses..haha.
