does the air bleed screw on the thermostat housing have a gasket washer as well as a metal washer?
thanks
no gasket under the washer, but if i remember right you need an odd size spanner and the brass nut rounds easily
thanks enri...i thought so, looks like the mechanic put a gasket washer under the metal washer and the coolant seeps out under normal torque
