841 - 860 of 879 Posts
That hot sauce you gave me is HOT, even for a Texan!
Discussion Starter · #842 ·
:oops: :ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO::ROFLMAO: that made me laugh.. would have loved to see the look on your face.... that Korean drinks i gave you and your wife , might help, cool you down
They are in the fridge, haven’t tried yet
Discussion Starter · #844 ·
speedo sender work... i bought this.. 16 pluse per rev..i need 8, so i took it part to see what was inside.. i wa hoping it was going to be 16 little steel or brass arms.. well nope..oh well is was only 34$
Fixture Household hardware Nickel Gas Plumbing
Green Gas Electric blue Circuit component Fashion accessory
Green Automotive tire Audio equipment Circle Door
Discussion Starter · #845 ·
so i a, trying a oem sender amd dremaling the body down to a smaller size..the room i have to work with is small.. so far,, mad it smaller,, can go another 5 mm,, then i will use a heat gun to slowly bend the plug over as mush as i can
Motor vehicle Wood Bumper Machine tool Road surface
Electric blue Plastic Cable Machine Electronics accessory
Engineering Machine Auto part Household hardware Nickel
GPS sender can be your friend! Get a speedometer delete plug for a t-5 from B&M to plug the hole.
Discussion Starter · #847 ·
if it comes to that lol but i like to do it the hard way..first..test my skills
I haven’t used one before but am interested for my build. I’m planning a digital dash for the short term that can read via the OBD port. Have you had experience with a particular sender you would recommend?
I have a generic gps Speedo in my gtv6 but have an Intelletronix digital instrument cluster to eventually use and they have a sender to go with it. Will also be using one in my spider after I get it on the road. I also have a T-5 and there is no room for a speedo sender ( sorry for the hi-jack Randall 😃)
Motor vehicle Hood Automotive design Clock Toy
Watch Gauge Analog watch Automotive tire Clock
Motor vehicle Automotive tire Gauge Measuring instrument Gas
Speedometer Gauge Vehicle Odometer Motor vehicle
Discussion Starter · #850 ·
y also have a scan tool that i can use, short turm
Thanks for the help. And my apologies as well for getting into the weeds. Carry on, boss :)
The only scan tool I have is a giant FMC Autoscan 4800 from the 70’s. A
Motor vehicle Trunk Vehicle Electrical wiring Automotive exterior
little to big to fedex
Discussion Starter · #853 ·
a little easier to use..lol
Communication Device Measuring instrument Font Motor vehicle Gadget
But I got way more dials and buttons!
Discussion Starter · #855 ·
yup..lol, i have a freind in the air force.. he drove c5's he let me see the flight deck one day.. i asked him about all the buttons. etc.. he said only a few really worked,, the rest were to keep us happy
Then you need a 164! I swear my 164s had more buttons than the space shuttle
Discussion Starter · #857 ·
thanks..i will think about it :unsure: :unsure::)
Discussion Starter · #858 ·
try the header downtube agian
Urban design Font Art Road surface Pattern
Discussion Starter · #859 ·
my plan to get it ...right this rime..... this is a slip fot tubing in the middle section.. fit and trim as needed to fit in the little space that i have.. mark it carefully... pull it out, and epoxy the tubes.. bottom one first, stuff back in reset the tube.. left epoxy setup,then do the top one the same way.. let set... then pull it out add a few tack welds, recheck in the car..if..ok.. i well weld the tubes togeather....will try a experment with a slip joint and extra tube and epoxy then weld to make sure
Discussion Starter · #860 ·
added the plastic pipe, so i can see if the if the pipes might hit the body, and get a better bend
Wind instrument Gas Tool Musical instrument Flooring
