1 - 9 of 9 Posts
Hello everyone,
I am a new Alfa Owner ('88 Spider Veloce). My seats are soft and mushy - any recommendations on the best new seat bottom foam. I had read a few posts from others that said the IAP foam does not fit well. What about the seat bottom foam from Centerline?
Thanks in advance. I am learning lots from this forum already (and from the car as I inspect it more closely :(
Wade
Hello and Welcome to the BB!!
I cant help with the IAP vs. Centerline but when I had my seats reupholstered, I had the shop redo my seat foams as well and they turned out nice. You might want to check around and see if any upholsterers are willing to do the foams for you. It might be cheaper as well.
Hmm...are those the original seats? They look like they have the foam bottoms from a later S4 model. I could be wrong here...maybe they went to those seats in '88.
In any case, you may not need completely new foam. If the foam in those are like mine, there are a few big open spaces where your butt goes. If it's the butt area that's saggy, you can probably remove the seat bottom foam from the metal base plate and stick in some supplemental foam blocks to fill the spaces. Cheap, easy, and no need to undo/redo all the hog rings on the bottom upholstery.
My '87 Veloce seats look like those, except black w/red stitching. The '88 seat are similar, but have taller shoulder belt guides on the inside corner, for use with those bizarre motorized belts.
Discussion Starter · #5 ·
Thanks everyone, I will try Gubi's idea first. Then check out the local upholstery shops.
Wade
I put a new foam bottom in the driver's seat last year, Centerline, made in Italy. The shop had problems making it fit. My guess is the foam expanded too much after removing from the mold. I had the shop trim it to fit. They padded the existing passenger seat bottom to match. The shop was somewhat confused why I supplied the new foam, they're used to re-padding existing seats. The new driver's foam was definitely worth it, very comfortable compared to before.
In retrospect, I suppose I could have vacuum bagged the new foam in one of those info-mercial storage bags to shrink it back to size temporarily to pull the new cover over it.
I just redid my seat bottom this weekend with foam from centerline. The size of the foam from them is correct. It takes some compression to get the cover on initially (which it should to fit properly) but once on it looks great. I did it myself and it was about a 3 hour job start to finish. In another thread I talked about the fact that I sit up much higher which I still haven't decided if I like or not. My foam was completely worn out and with the new foam I am sitting 3 to 4 inches higher in the car. At a little over 6 feet tall I am now looking at the upper bar of the windscreen and the sun visors. I am still debating replacing the seats with aftermarket seats or just wait for this foam to compress over time like the old foam did.
Ventura Alfa
Ventura Alfa
What year spider? THe veloces from 86 up have a different bottom
1 - 9 of 9 Posts
