1 - 9 of 9 Posts
Maybe APE? (209) 833-8330. If it's a solid-steering-shaft box, I think you'll have to get another Berlina one. If it's a US 2000 car that has a U-joint shaft box, you should be able to use a similar box from a US 2000 GTV.
Andrew:
Wouldn't any solid shaft box work (Spider/GTV/Berlina)? If it is a different length shaft (and a recirculating ball style) couldn't you take the shaft assembly out of the original box and install it in the donor box? They sure all look the same from a distance...
I have a couple of broken burman boxes that just this week I pulled from parts cars. I haven't yet looked at them to see how repairable they might be but if rogerspeed or someone else can't help, let me know and I'll take a look at them.
Good luck!
The box is the same, but I'm not certain the shaft length is the same. If someone can confirm that, then yes. I don't offhand know how the shaft housing is attached to the box and whether it's easily changed; if it's bolted, then yes. If pressed, a tougher job.
I didn't know anything about the u-joint boxes until a few weeks ago, but the solid shaft boxes can be interchanged. The shaft lengths are different, but you can swap them. Did this a couple of times with GTV and Spider boxes (the shafts are different there, too).
Cheers,
Karl
1 - 9 of 9 Posts
