1 - 12 of 12 Posts
Alfa 105/115 parts to clear. Most stuff is 2000 Berlina, which I just parted, unless otherwise indicated. Pick up in Berkeley, CA, or can ship small stuff.
Interior
* Package shelf for AC car (fits reg. Berlina and Giulia w/ slight mod) $20
* Two map pockets for right kick panel (also Giulia). $5 each
* Light tan door panels; RF (has speaker hole), LR; good, slight sunburn top edges. $20 pair
* Pair door opening stainless kick plates. $15
* Pair interior light switch with covers (Giulia too). $10
* Pair sunvisors (Giulia too). $30
* Set four window winder handles. $20
* Pair kick panel air vents (Giulia too). $5
* Pair retractor-part rear seat belts. $5
* Giulia TI instrument pod. $25.
* Giulia TI red/amber taillight lens pair. $20
Exterior
* Three 5 3/4" headlight buckets w/ retainer (two inner, one outer). $15
* Four rectangular side marker lights w/ rubber bases (1971 on). Also GTV. $20
* 2000 Berlina center grille. $10
* Three cowl body pieces over wiper assembly. $25 each
* Hood. $50
* Trunk lid. $40.
* Several doors. $40 each.
* License light shelf w/light and ALFA ROMEO script. $15
* Stainless side spears under door. $30 pair.
* Left vent window (windwing) w/ gasket (Giulia too). $20
* Pair vent window gearboxes (Giulia too). $10
* Pair C-pillar chrome air extractor vents. $25
* Bertone badge; faded. $5
* Glued-windshield shiny trim (missing small bottom center clip) $20
* Pair front turn signal units (also GTV, 70s Spider) $20
* Full-width Giulia TI grille. So-so. $25
Mechanical
* Bosch SPICA fuel delivery pump (also GTV, Spider). $75
* Main (front) fuel filter (no pressure switch) (also GTV, Spider). $10
* SPICA trunk vapor canister w/ valve (also GTV, Spider). $15
* Pair stock rear Berlina springs. $20
* SPICA air box. $10
* Rear axle trunnion arm $20
* Berlina main parking brake cable. $25
* Parking brake handle assembly w/ rack. Also GTV, Spider. $25
* Pair Koni front shocks, good used condition. Also GTV, Spider, Giulia. $50
* Pedal assembly (1971 on) w/ pedals, booster, brake MC (no res), clutch MC. Also GTV, Spider. $50
* Wiper assembly w/ motor. Also fits Giulia w/ slight mod. $75
* Pair wiper arms. $20
* Pair horns. $10
* Rear brake proportioning valve (also GTV, Spider). $20
* Full set of hard brake lines, good cond. $20
* Full set of hard fuel lines w/ insulation. $20
* Two sets Berlina hood latch mechanism. $10 each
* Late 70s Spider air pump (probably Alfetta too). $30
* Alfetta air injection rail. Excellent. $30
* Fuse box (also GTV, Spider). $5
* Rear sway bar (also GTV, Spider). $15
Email [email protected] or call (510) 526-0391. Sorry no pics, but can show parts in Berkeley. Have other odds and ends too, esp. for Giulia sedan and Berlina, so please inquire.
benji, This is my first time purchasing an item. Your price$30.00 is accepted. Where do we go from here. By the way, do you have a heater motor for a 72 GTV? Thanks, billb
I have hard brake line sets from two 2000 Berlinas. What are you looking for? I didn't label them on removal, so it may take a bit of figuring as to which is which, other than the obvious ones, like the long one that goes to the rear. Email me at [email protected]
Hi Andrew:
I emailed you some time ago, and I just got the message back that it was undeliverable for 88 hours - something must be up with your email? I could not get throughthe queue. Anyway, the ones I need are the short ones that run to the front caliper, on a GTV or spider they curve back on themselves and are about 10 inches long with a female on one end and male on the other.
thanks!
1 - 12 of 12 Posts
