Hi,
Can anyone confirm my suspicions before I fork out £350 for a new Master Cylinder...
My Berlina 2000 RHD brakes were at the bottom of the pedal travel and not very effective OK to stop but not in a hurry.. so i have stripped the front calipers and installed new piston seals and dust seals as both were not pretty.
Now 3L later of Dot4 fluid i still get very very fine air bubbles in a constant stream as i bleed the two front calipers..
i can now drive the car and with a quick pump the brakes are great but on a first push of the pedal the brakes are similar to how they were..
i suspect a small amount of air is passing the master cylinder piston seal on each stroke..
Any ideas before i go nuts please :)
RHD, you have two boosters? Have you confirmed that they're OK, not filling up with fluid? It's common as they age.
Discussion Starter · #4 ·
Hi, yes two boosters. they are both relatively new (been refurbished not long ago)..
The MC bleed nipple will not bleed and is very old this is why i think its the MC.
thanks,
