Hi All
I know there are other threads dealing with tyre sizes, but what I'm after opinions on, is what tyre size to use on the GTA 15" replicas from Alfaholics that I'll be putting on my 1750.
Based on the original tyre size 165/R14, which I believe were about an 80 profile, the closest overall diameter size is going to be a 195/60/15. However, performance tyre choice is limited in this size, in fact there are no true high-performance tyres in this size available in Australia.
There is however a wide choice of performance tyres in 195/55/15, however that size will be about 30mm smaller in overall diameter than original size.
So if I use a 55 series tyre, there are a number of issues:
Then of course there is 205/55/15, which would be a suitable diameter also, but I don't expect I'd get 205mm under the rear arches, and the steering would also be too heavy I think.
So can anyone speak from experience? Is anyone running 15" rims on a Berlina, and if so what tyres are you using, and do you have any pics so I can see how they fill out the wheel arches?
Also, does anyone know who owns this grey Berlina? As it has an identical stance to what I am aiming to achieve, and it looks to have the 15" TZ rims, so I'd love to know what tyres, springs etc are on it.
Cheers
Damien
- speedo will be about 4-5% out.
- the car will be geared slightly lower which is not so great for highway cruising. Will also have a lower top speed, though that's incidental unless I'm on a track, which I may be occassionally.
- the car will sit about 15mm lower, and this could be a big deal as I'm fitting the Alfaholics fast road kit and am expecting the car to sit 1" to 1.5" lower anyway.
Cheers
Damien
