For adapters, I would suggest that you speak with Charlie DiMarco from Serpent Auto Sport.
Best regards,
For adapters, I would suggest that you speak with Charlie DiMarco from Serpent Auto Sport.... I guess I would need some kind of hub adapter to get the 5X98 size/ pattern?...
You can fit them, Use a VW 5X100 and Et 30-35, get some adpaters made and wobble bolts, simple.These are my favorite wheels for any car. Would love to put them on my 164LS. Can you inagine how great they would look? I guess I would need some kind of hub adapter to get the 5X98 size/ pattern?
BBS CH Wheels - Wheel Size & Price Details - 1010tires.com
Yes, they are popular on AudisYou can fit them, Use a VW 5X100 and Et 30-35, get some adpaters made and wobble bolts, simple.
I can help if needed. I have sold a lot of these wheels to VW/AUDI guys. I have good prices on them if interested. Also have adapters and wobble bolts and a good price as well.
17x8.5" CH, 35mm offset, 21.5lbs: $385 per wheel (others: $412 each). $79 for a set of wobble bolts and around $20 for adapters, no tire combo's anymore but I can do it if you really want it. You pick the tire (Will meet or beat tire rack prices and have some brands they do not have) and I can have it mounted and shipped. Will need a 10mm spacer on the rear. I also have Eibach pro-spacers $79.50 a pair. Recommended tire 225/45
Ciao!
JAson
They will be around for while. So no hurry! Always there if you want them.Yes, they are popular on Audis
Wow TemptingThanks, just gotta budget the 2500 it would cost to do this
Not right away, but 2008 for sure
WOW. Those look great!They will be around for while. So no hurry! Always there if you want them.
BTW a 5mm spacer on the rear would work fine as well.
Good looking wheel. Never have seen one on a 164 but is an option and looks similar to the siena for example. So I can see that it could work.
Only 164 I have ever seen with BBS wheels is seen here:
http://www.cuoresportivo.ch/e107_pl...eo's/Alfa Romeo 164/pv_Alfa-Romeo-164-1-1.jpg
Big picture I rather not post.
Another with similar BBS style but deep dish which IMO does not look good but would have with the same wheel non chrome and non deep dish:
I understand these look nothing like the CH's but they have the similar styling which can give you an idea.
If someone can PS these wheels to a 164 that would be cool.
Jason
I have three sets of wheels.If they're nice 16's or 17's I get first dibs when you upgrade!!!
bob
I would go with a lower offset like <35mm. I will have the Eibach Pro-spacers available. 10,20,30mm 10mm is a non-hub centric as the hub/wheel will not need it but a 30mm long bolt is need which I supply.hey Sam, the CH's are a good lookin wheel. I say go with Charlie to get adapters made. The min thickness he can do is 20mm, so go for a higher offset and probably not anything more than 8" wide. Charlies's adapters are hubcentric with the alfa hub and can be made to be the same hub bore and bolt pattern of the wheels. My BBS's have a 35mm offset with the 20mm adpaters and they meet up right with they fender, with plenty of room between the 225/45 tires and the struts. The 17x7.5 CH's with 42mm offset will be 7mm closer to the strut than my combo, but will give you more clearance from the tire rubbing the fender. Also, keep an eye here: VWvortex Forums: 5x100 Classifieds
There are many nice sets of used BBS wheel/tire combos for sale there whihc could save you a bit of cash.
Well not too high though. You have to remember if your going with a higher offset to offset a spacer for a reduction in offset you would also have to use a spacer on the front to lower the offset as well which IMO does not work well. I do not recommend a spacer on the front at all with a wider wheel.Yeah but if he is going to get the adapters from Charlie, Sam should probably look for a higher offset wheel. For example, the 42mm offset CH's would have a 22mm offset with the adapters, which just about clears from fender rubbing.
Nice work Mike. I think they look good but not 100% unit they are on the car.Heres a quick photochop that I did
Now, now Bob You say that as if there is something wrong with having 12 wheels for my Alfayou let me know when you get set #4 and which other set (assuming you only need 12 wheels , not 16!!) you would be willing to part with! (As long as they are 16's or better and not the great looking. but TOO MUCH WORK TO CLEAN phone dials!!)
bob
Mike - looks great! ThanksHeres a quick photochop that I did
Wow, thanks againYeah I made them the same size as the Alessio wheels that were on your car in the picture
