1 - 5 of 5 Posts
Quick question... 69 Spider drives fine but occasionally when driving I will hear a single loud backfire from the exhaust. Anything to be concerned about? Cause of this? thanks
Is it SPICA or carbs?
Does it happen when you are cruising with steady throttle or when you take your foot off the gas?
A cylinder not firing perhaps? Unburned fuel vapor then hits the hot exhaust, and 'boom'. Or maybe a timing issue.
Common occurrence with Spica injection. You need to lift completely off gas pedal during deceleration. As I recall the cause might also be a faulty micro switch in the injection pump.
Cheers, Jon
1 - 5 of 5 Posts
