Mine has the connector in the back behind the convertible top to plug the hardtop defroster into, but no switch anywhere on the dash. At the box, it appears that the relay is connected in the back as the relays with just fall out without the corresponding female connectors in the back. (I know this from the used fuse box I purchased.) Other than no switch, it makes sense as Graduates were prewired for everything the Veloce and Quads had. For instance, I have the connections behind the dash for the map light and the mirror vanity light. The power window wiring is also present in the center console and the wires terminate behind the doors. I thought about adding them to the car prior to cutting holes in the new door panels for the cranks, but decided against it. More $ and something else to go wrong.
Can anyone with a Quad tell me where the switch for the rear defroster would be located?
