hi folks, this washer came off during the GTV6 driveshaft or steering rack removal, found it on the ground. anyone recognise it and can advise where it goes ? its about an inch and a half in diameter (3cm) and half inch thick (1cm). metal, coated in rubber. thanks!
ok that makes sense, will see if the others are still attached, may have fallen off when i raised rear axle to disconnect driveshaft rear end. thanks.
Things get dropped down engine bays all the time, and the steering rack is a good catch-point. Extend your search upwards when look
