Just curious if anyone does there own wheel alignment. I have been doing my own alfetta alignments for years. Now I have this adjustable rear end so I find myself having to align all four corners of the car. Level ground, marker, string line, tape measure, ruler. Any suggestions or methods that might help.
In a nut shell the front track is wider than the rear so i run a string line around the front of the car/tires to a pair of jack stands at the back of the car that are set apart the width of the front track. Set the string line the same distance from the center of the rear wheels either side and you should have a pretty accurate rectangle around the car. With this im just looking at the toe.
