ANSI or Ansa? Any way, you can gain some clearance by loosening the three bolts that connect the rear to the mid pipe. In a perfect world the two flanges should be parallel to each other, I would check that first, if it is parallel and still hitting then you can slightly tip the rear downward bringing the two rear portions off the flanges closer. It will still seal even if not parallel.
