Exhaust
A good quality exhaust is excellent and will last a long time, but you do not need to spend big dollars to get a nice sound, basically with Alfettas, GTV Guilietta GTV6 90 75, you cut out the rear baffle section, can't rust out on you if it's not there, run your favorite size pipe size straight thru from the first baffle section to the rear and put a chrome dump on the rear with a flare, you can tune your favorite sound via the dump size you put on, all this can be done including labour for under $200.00 :whistling:
