Alfa Romeo 2.5/3.0 Flywheel
Our GTA performance flywheels are made in our shop from 6061-T6 billet aluminum and are setup to work with your OEM driveshaft donuts. We harden and swarte our ring gears to the flywheel with button head screws that are counter bored between the flywheel and ring gear. Allen head bolts are supplied for mounting to the crankshaft. These are the same flywheels we designed and fabricate for our Alfa Tipo and TZ recreations. Each one is custom-made so we can adjust the weight to your specs.
We also have 1300 105 tooth flywheels, 1600 105 Tooth Flywheels, and 1750 110 Tooth Flywheels.
Check them out at gtamotorworks.com (Click on the store link.)
