1 - 12 of 12 Posts
The straps of the rear suspension are held in place by 2 bolts that pass through an aluminium block. The question I have is what happens if you replace this aluminium block by a steel block. Aluminium causes corrossion problems when in contact with steel.
I just can't stop thinking that if Alfa engineers used aluminium for this, that they did it because a specific reason. Aluminium is more expensive.
Reviving an old thread ...
Could someone post exact dimensions of these alloy blocks? My car is undergoing surgery at the rear end at the moment and I'd like to fit a pair of these, as they were missing when I purchased the car and I've never sought to remedy this situation until now. With these dimensions I'll machine a pair and have them hard anodized for corrosion protection.
Thanks in advance,
Alex.
Al - block dimensions
Outer dimensions: 110 x 30 x 10 mm
Holes: Ø 10,5 mm distance 84 mm
Slot: 65 x 20 mm, 5 mm deep, radius 7 mm
When installing, slot is on the upper side.
Slot has no real function.
Thanks for posting those details.
I'm actually referring to the style of alloy spacer blocks pictured here. As far as I am aware, this version was the only kind manufactured for early 105 cars, but I'd appreciate any further input about the thickness of these spacers if the car has been lowered a little.
In any case, the plan is to have at least one pair cast locally as they seem to be NLA.
Alex.
I have a spare pair of those complete assemblies in decent condition. They came off a southern car that probably never saw road salt. Even the screw heads are almost perfect. Let me know if you want any of the parts. They are cheap. I can post pictures if you are interested.
When you put shorter sport springs is better to remove those spacers or shold they stay ?
These block have no effect on the cars ride height, they only spread the load applied to the limiting straps. If you've lowered your car, you should also shorten the limiting straps such that if they do what they are suppose to do, in that the springs remain with a little pressure on them. But if your talking about the rubber stops, they should stay in place.
just coat the block with anti-seize, or grease, that will prevent it from corrsion.
You're correct. Limiting suspension travel by lowering and allowing the axle to hit the bump stop while cornering results in an infinite spring rate. This means that wheel will loose traction first and give instantaneous oversteer (ask me how I know).
I took mine out when I lowered it so as to get a little more suspension travel.
1 - 12 of 12 Posts
