This all happend after I was driving and when I got home I noticed light stayed on , I check and the diode plate bolt was loose and touching the casing causing a short , but I fixed that and still nothing
This all happend after I was driving and when I got home I noticed light stayed on , I check and the diode plate bolt was loose and touching the casing causing a short , but I fixed that and still nothingI got alternator problem , the dashboard light stays on even with key out ignition , the alternator does not charge , everything seems wired properly , b+ to battery , DF to Df on regulator , D+ to D+ on regulator plus green wire connected to d+ that goes inside the car , and D- connected to nothing ?? My regulator only has 2 terminals and is earth on the body
