Sale is over but some items still on sale till mid July
Lots of good stuff, rare stuff, all OEM unless specified. All orders need to be called, e-mailed or faxed in. (+1 480-858-9156 TEL/FAX), +1 480-330-0844 Alt. TEL.
(PLEASE NO ALFABB INSTANT MESSAGES-just e-mail me or call
**Some items are limited stock. Once they are gone they are gone at that price. **
Pre-Summer Sale ? Alfissimo International
Lots of 164. Milano, Spider, 166, 33 and other parts on Sale!!!
Thanks everyone.
Alfissimo Pre-Summer SALE!
Tons of OEM parts and used parts on Sale now. Lots of rare parts and special tools on Sale.
Sale is OVER!!!
Please contact me via e-mail or phone for orders;
Items NEW on SALE: (164, Spider, Milano(75), 33, GTV (916) more...
Parts On Sale:
1149S- Koni Sport REAR Strut Pair- 164 - $365.00 ( 1 sets avail)
71736144 -Spider Air Filter- OEM- $17.50
71736138 - Air filter OEM 164- $20.50
71736107 - Fuel Filter OEM 164/Spider- $21.00
46805830 - Oil Filter-OEM - $9.00
49878/3200- 166/156/GTV -24V Valve Cover Gasket Set kit (with spark seals)- $59.00 (made by SPESSO Italy)
60605378- 164 Windshield OEM SEKURIT Heated- $1,150.00 (last one available) Freight and Crate fee not included.
60561377 - Serpentine Belt Bracket 24V 164-OEM- $125.00
60504386 -**33 Radiator -(905) 1.2,1.3,1.5 1973-89-Italy- $159.00
112723860 -24V 164 Radio Lid-OEM $46.00 (**2 left. Gone forever)
60778485- HORN BUTTON/RIGHT 91-93 steering wheel- $27.00
60778486- HORN BUTTON/LEFT 91-93 steering wheel- $27.00
*Spider 1990-94 (S4) FLOOR MATS Black with red- $80.00 (perfect fit!!!)
9945109- 164 Headlamp Lens Right side w/ seal, clips - EURO Headlamp- $130.50
71738911 - 164 Rear brake disc- OEM- $67.00
60601063 164 24V Brake Master Cylinder (w/o Booster)- $185.00
B+G Performance Lowering Springs- 164 - $265.00
60567605- Rear Main Seal- OEM- V6 - $21.00
**55202772 - Timing Advance Variator TS-16V-OEM $199.00 (2 available)
60547732 Cup for steering linkage- Spider- $1.50 (2 avail)
5972332- 164 Motronic Coolant temp sensor- $18.00 (Edit)
60605959- Coolant Sender- 24V 164 - $29.50
60516367- Driveshaft spacer -spider- $12.25
60521379 - Bushing Sleeve Sway bar- Spider- .75
**Fixed V6 Tensioner- NEW - $100.00
82404889- A/C Probe- 164- $40.00
Trunk Strut 164- $17.50
60572039- LS Front Grill- $110.00
*60701207- Milano/75- Windshield Gasket- $12.50
60544488 - 164 B/L- Intake Air Hose- $32.50
60547303 - 164 S/QV Intake Air hose- $44.00 (4 avail)
7655061- Diff Bearings-164, 156, spider... -$37.00
60808449- Transmission Bearing 5th- 164- $51.00
*ATE Rear Brake pad set- 164- $47.00
60513135- 164 Early Pan Gasket( up to #004699) OEM- $25.00
60652886- Colored Wheel Badge-60mm OEM- 10.00 each
46408830 164 24V Hand Brake Cable -164- $45.00
60589343- 164-24V mirror control box-OEM $60.00
292062203- Steering Knuckle Bearing/FG- Spider-OEM- $19.50
60513382- Rod Bearing- BLUE-OEM- $4.25 (6 avail)
60568882- Main Bearing- RED-OEM $7.25 (6 avail)
60513381 -Rod Bearing- RED-OEM $4.25 (4 avail)
Bonaldi/Bendialia Clutch Slave Rebuild Kit- Alfetta/Sp- $5.50 (4 avail)
60510360- Ball Joint -164 OEM TRW- $43.00 (only 1 left)
60539949S- 164 Coolant Tank-$75.00 (w/o sensor/cap)
60585698- 164 Door Check,OEM- $8.50
60556894- 90-94 Spider Rear Lamp- $200.00 (rare part- $289.00 regular)
7659720- Transmission Fork Bearing, OEM- 164- $4.00
60511726- Brake Level Sensor, OEM- 12V 164- $19.50
46411473- Elec. Susp. Transmission Switch 164, OEM- $12.50
7624310- Speedometer Sensor- 5 speed 164, OEM- $125.00
60610985- Cam Seal OEM- $9.50
82429744- Upper Rear Strut mounting plate-, OEM $34.50 (2 avail)
(only the section that holds spring pad, not upper bushing)
Alfetta 2.0- Front Flex Disc-Italy $75.00
Alfetta 2.0 - Mid Flex disc-Italy $45.00
Alfetta 2.0 - Rear Flex disc-Italy $75.00
Spider-Coolant Cap- $8.00
60777705- Spider- Exhaust manifold flange Gasket- OEM- $10.50
182 0275000- Special Tool- 24V insert for Serp Belt- $30.00 (2 avail) out of production
182 0617000- Flywheel Holder- 155, 2.0 TS 16V- $40.00
164 SuperPro Rear Poly bushing pair- $19.00 (made in AU)
60561615- Serp. Belt Idler 164 24V- $85.00 (1 avail)
46403499- Transmission Ball Bearing- 164,GTV,Thema, Spider OEM- $71.00
46403722- Roller Bearing- Transmission- 164 update- OEM $76.00
Throttle Position Sensor-24V 164- $50.00
Used Items on Sale: (see used section on website Alfa Parts | Alfissimo International | for lowered prices on all parts)
60501443 Spring Perch- Right 164- $65.00
Air Flow Meter- 164S only- $200.00
164 S ECU- $250.00
164 LS ECU- Repaired- $300.00
***164 FOAM (raid air) Airfilter (made in Germany) 3 layer filter- $65.00 (no longer available new)***
Left Turn Signal- 164 LS/Q- $40.00
Marelli Distributor- S103 BA (extremely RARE!!) - $175.00 (great condition)
60597876- EGR VALVE- 164 24V USA- $175.00 (list $497)
S Badge- $4.00
60808222- Hydraulic Tensioner with feed stud (welded shut)- $100.00
Thanks everyone.
Sale is OVER!!!
Parts On Sale:
164 S ECU- $250.00
S Badge- $4.00
