I've read many discussions about the oil pressure and oil pressure sender problems. During all this reading I learned, contrary to my understanding, that the switch behind the alternator on the 2L engines is a low pressure switch and not a low level switch. I opened up my wiring diagrams and noticed that the 79 Alfetta does not have such a switch. My engine has been replaced with a Twin Spark which has a switch at this location. I also verified that I have no wire in the engine bay around there for a switch. Can anyone confirm that this was indeed not needed and there is no dash light that can be used for it? I would like to add a switch with a light in the cabin. Did anyone do that?
I also noticed the orientation of this switch on my 74 GTV is straight out of the engine, and on the Twin Spark engine there is a banjo fitting and the switch is parallel to the engine. I think late Spiders have the same as the Twin Spark. I have a diagram below showing this orientation. Is there a problem with the old way to do it, screwing the switch straight into the block?
I was even thinking of using a tee fitting here to have the switch and an aftermarket sensor and put a new light and gauge in the cabin to compare to the Alfa sensor/gauge. Has anyone done that before? Would the heat of the exhaust manifold pose a problem to the sensor?
Stefano
My 78 Sport Sedan has the boss but not drilled and tapped.
OK, that makes sense. The engine that came out of my Alfetta was originally from an earlier GTV and the mechanic who installed it put a plug in the hole. I wonder why the Aftettas didn't have it. Spiders at the time and later still had it.
Yep. My 78 Spider has it.
Alfettas don't have the crankshaft drilled for a pilot bushing either.......
I was hoping the Alfetta had the oil pressure boss drilled. That would make it way easier to hook up a mechanical gauge for testing purposes, without removing that factory sending unit. I made a special wrench for that though.
Both Alfetta's and GTV6's did not have a low oil pressure switch. For many years I had an alfetta block engine in my Spider and I had no oil pressure warning light. Later I fitted a 164 motor into my GTV6 which had an oil pressure switch but no warning light to connect it to.
That sounds like a reasonable upgrade to get a low oil pressure lamp.... LOL.
I have a nice warning light that came from a 246 Dino I got real cheap from eBay. I've been dying to install it. I wan't to compete with Homebuilt by Jeff (if you follow that build) and have a Alferrari (well, electrics anyway). I already have a power terminal block from a 308 feeding the wiring harness.
