1 - 1 of 1 Posts
Alfetta oil pan and oil pump, just removed, working, from a 1600 engine intended for a Giulietta. Removed to swap back on a normal 105. Worked fine, had good oil pressure, has run on test stand, have not driven it. Small area of grinding inside rear of pan for 105 rear main clearance, won't affect use on Alfetta engine, likely required for 750 or 101 use. $175/BO, pick up in Berkeley or can ship for cost.
1 - 1 of 1 Posts
