Garth,
I fit the running gear and electronics from a 1982 GTV6 (U.S.) to a 1977 Alfetta GTV (U.K.) about fifteen years ago.
Mechanically, the hardest part of it was modifying the chassis mounting points for the motor to V6 specs. From memory; I used the GTV6 engine, bellhousing, driveshaft, couplings, centrebearing and housing (holes required enlarging), transaxle & halfshafts. I retained the Alfetta subframe/deDion and using the GTV6 hub-carriers to mate with the GTV6 half-shafts, retaining the 4 lug wheels.
I didn't change to the GTV6 front torsion bar and brakes, though if I had the budget for it I would have. The standard T bar worked surprisingly well with the extra weight (maybe due to the bilsteins?). The brakes coped well also, never once showing signs of fade, though driven briskly.
Electronics. The GTV6 ECU and ECU harness were installed in the standard GTV6 position and spiced into the Alfetta electrics with about 6 hrs work, by an auto electrician. The GTV6 tach was used and I don't remember how what was done with the speedo (sorry).
My research at the time indicated that the 4cyl tranaxle and half shafts had been used successfully in the past (and were lighter
), but I thought the stronger transaxle was worth the extra expenditure. I had had problems with the 4cyl couplings, so I was glad to upgrade to 6cyl shaft and couplings.
Should you decide to go this way, I suggest acquiring an entire GTV6 donor vehicle and doing a direct transplant. The standard 2.5 is a joy but will not add much performance (if any) to your current set-up. Now a 3ltr is really worth it!
