Hi guys, I have finished the body/paint of my 82 alfetta-gtv, and I am currently putting the car back together and having the fuse box cleaned contact by contact with a wire brush with aid of a Dremel, replaced all fuses and relays and found that the place where the flasher should be installed is empty.
Seems that previous owners were not very wise on the electricals and the car has two 2-prong flashers (marked X-L as I can recall) installed, one clicks when I operate the turning lights and the other when I use the emergency lights so I guess that each flasher controls different functions of those lights. I must mention that the light in the dash (green with the arrows) doesn´t light up if I use the hazard lights or the turning lights.
I want to re-install an original type 3-prong (X-L-P) flasher in the fuse box, so I would need some help from you. How should I wire this flasher?
- Should both of the wires that go to the X on each individual flasher be wired together into the X-prong of the flasher? Should I wire also the wire that triggers the dash light here(I think it is green)?
-Which wire should go to the L, the one from the turning light flasher or the one from the hazard light flasher?
-Which wire should go to the P, the one from the turning light flasher or the one from the hazard light flasher?
Thanks for your help.
