1 - 9 of 9 Posts
Hello can you convert a us column switch for a Alfetta gtv from a us type to euro type so the main and dipped beams stay on simultaneously.Hopefully someone has done this.Thank you
1988 Sprint 1.7QV, 2009 159 LE
I could be wrong here, but I think it should just need a different relay (s). Swap from changeover type to make/break type.
I only say this as I bought the wrong type for my Sprint so when I put main beam on the dip went off.
Worth checking out
Push hard and live
I recently installed a new column switch in my 78 Alfetta GT. I was told it came from Australia, or maybe New Zealand, but can’t confirm that. It was somewhat different from the one I removed, primarily in having a fourth wiper position for intermittent wiping. Some of the wire colors were different, and there were two plastic connector blocks instead of one like my original.
It took a while to match up all of the wires, but it works fine, and when the Inner high beams are selected the outer beams remain lit.
If you have a Australian type switch you would have had to re wire anything to have the dipped and main lights working simultaneously.You may had to do some rewiring for your wipers.
Push hard and live
It turned out to be a straight forward job. Like I said, I’m not certain exactly where the switch came from, or whether it was an Alfetta GT switch. It might have been either a later model Fetta, or even a GTV6 switch. It bolted into place, and required only a little pin-out testing and pin reassignments to get everything up and running.
To be clear, when I switch from low to high, the outer beams stay on, but switch from low to high filament, and the inner beams come on. This would be normal for a US car, so I thought nothing about it.
However, if you are seeking to have the outer beams keep BOTH filament sets lit during high beam selection, I’ve never seen that. It would be a ton of current and heat in the two outer lamps.
Push hard and live
The wipers were the easiest part of the hookup. Once I realized the switch was a four-position unit (off, int, slow, fast), and my car had circuitry for only off-slow-fast, it all made sense. So, at present, I have two off positions. I’m lazily looking for an intermittent controller to add that function.
Spiders from the early 80's to the end had them. APE probably has a box full of them.
Hi my car is a euro car . Australian delivery but I have a US type switch as I brought it at a good price.My car should have both inner and outer working when high beams are on.
1 - 9 of 9 Posts
