Had a chance to work on Rocky a bit this weekend. A variety of jobs as the weather was quite varied.
Friday / Saturday: We had a snow storm blow through, so working in the barn would not be too pleasant.
I had pulled the clutch assembly from the transaxle that Witty had dropped off earlier in the year. Popped off the pressure plate and the disk looks good. A little wire brush work and the flywheel and pressure plate look decent - at least I won't start out with a stuck disk! Will need to pack the throw out bearing, but it turns smoothly. Very interesting how different the Alfetta clutch is from the GTV6 or Milano.
Spent the cold part of Saturday cleaning the clutch housing. Degreaser and scotch brite pad made it look very nice!
Saturday PM and Sunday: The sun came out and dried up all the rain. So the itsy bitsy spider went to the barn again.
I figured I may as well look and see if the transaxle had LSD. (Hope springs eternal) So I cut of the hex bolts holding the spacer and remaining disk to the stub axle. Those hex bolts are awful. The Allen bolts of the more modern versions are way better to work with - hence the grinder for these. Then pulled the caliper and the side of the case. Nope - just an open differential. It looked good inside though. I will use this and the transaxle that is in the car to make a "rebuilt" using the best of the two. At least the one in the car has the Allen bolts. Probably means someone has already been in there. Hmmm... starting to think of LSD again.
Since it was warmer, I figured I would get the floor of the battery box welded in. If you remember, the battery had fallen through the bottom on the trip back from Chicago. The sides of the box and floor of the trunk were not terribly rusted, so easy enough to trim up. A lot of trimming to fit, overhead welding, sparks in the hair and weld flash. Now I have a good battery box floor. I will use seam sealer to cover up my booger welds and fill the holes between them, but given the condition around the repair, I am not displeased.
Before:
After:
Now I can start shopping for a battery and the car won't have to be started on the umbilical to the truck.
Since I had the welder out, the next project was to weld the ANSA muffler to the standard muffler inlet pipe. I had tacked this in place previously, so marked it well, pulled the pieces out and finished the job. The welds look a little better, since I wasn't welding overhead! Next steps at the rear will be to drop the driveline so that I can rebuild the clutch and brake lines. I'll need a full, warm weekend for that!
I had a bit of time left Sunday afternoon. I have never been able to open the passenger door. I knew that I needed to access the mechanism, which meant pulling the door card w/o opening the door. At least these are just screwed to the door, no fancy clips. About 1/2 of the screws came out and the other half need to be drilled because of rust. Once the screws were gone, the door card came off pretty easily. It was really flexible, soggy and moldy. I will need to rebuild that sometime.
Then came the PB Blaster and working to get the lock mechanism to move. Vice grips clamped to the rod, lubrication and a few taps with the hammer and the door would lock and unlock. The latches were still frozen. More juice, slow and determined working and suddenly the exterior handle opened the door. A bit more and the interior also worked! The bottom of the door held some rusty yuck, but I was pleasantly surprised that there
was a bottom of the door!
Still had a bit of Sunday left, so started all the cars in storage (The Vette, Milo, the white GTV6 and Rocky) and let them warm up enough to remove the condensation from the engines - and had a beer! Good progress.
