Hello apart from the clutch yoke problem . the person that workd on this car thought it wise .... to NOT place a oil seal on the input shaft inside the front of the transmission housing ....... creating a large oil leak ...... ( understatement ...)
The issue is ...... , not having the old seal as sample , does anyone know what size inner and outer diameter seal it is? since transmission is sitll hanging on car its quite difficult to measure and be sure of correct measurment with vernier caliper up there . And since its not excactly a fun job to repeat in the case the seal would leak .... i would rather have some more precise information as to what size seal it needs. I appreciate if anyone has the information thank you ..
i do not know . its input shaft seal behind the cutch fork at entrance of bell housing
