So…my recently installed OKP Sport Exhaust on my USA 1976 2.0 Alfetta GT sounds and performs wonderfully. No issues the past year or so including during some warm weather (not hot) driving. BUT I recently had some brake issues = squishy pedal falling to the floor after some hard driving. After cooling and a couple of pumps the brake feel would return to normal. Master cylinder is a relatively new 4 years ish so initially thought not to be an issue.
First things first, fully bled the brakes and new fluid all around. Pedal felt solid and stayed for a few days before I put the car down for testing. After some hard testing over a few miles all felt well…then pedal went back to the floor. A couple pumps and feel mostly returned. Limped home super slowly. Entering driveway there is smoke emitting under the hood and upon opening I see what appears to be the master cylinder dripping onto the new stainless steel manifold AND catching on fire! Fire extinguisher to the rescue.
Obviously master brake cylinder is leaking = replace it. Remember that this was a relatively new part - 4 years.
BUT thinking that the TRUE cause of this might be the heat now generated by the stainless steel manifold? Basically cooking the brake fluid and master cylinder?
Ideas and solutIons?
1) Folks say heat wraps can cause the headers to crack. Also apparently I need to take the manifold off to do the wrapping properly - not a task I am looking forward to.
2) Heat shielding. Picture of an idea attached. Not sure I can manufacture as lovely looking piece.
3) Upgrade to a higher temp brake fluid - I found a Super Dot 3 that goes to 500F (260C) as my previous regular Dot 3 went to 400F.
Leaning towards a combination of #2 and #3.
