I'm looking to recommission the A/C in my '79 Alfetta GT. I know sort of what the installation looks like, but it's been decades since I owned an Alfa of this era with A/C.
Can anybody post photos of the compressor bracket? Does it have an idler attached? Were there steel and aluminum versions? And finally, does anybody have a spare one for sale? Oh, if only the Alfarm were still around!
I have the original bolt-on drive pulley, and Vintage Air sells an adapter to fit the Sanden SD508 to this bracket, so those parts aren't difficult.
Any and all help appreciated.
Bob in Nashville
Here is a bit that I know. There were two systems for Alfetta. A high mount compressor and a low mount. Supposedly the low mount is preferred. I have the high mount on mine.
Pictures (not the best):
Motor vehicle Vehicle Car Gas Auto part
Motor vehicle Automotive exterior Vehicle Auto part Automotive design
Here are a few photos of the factory mount:
So yes, it has an idler pully attached. The lower mount is also used for the alternator. And as a side note, on the lower mount, I used a pair of rear upper sway bar bushings from a Milano to replace the bushings that had disappeared over the years on my car.
Automotive lighting Automotive tire Hood Motor vehicle Automotive design
Motor vehicle Gas Automotive tire Auto part Machine
Automotive tire Vehicle Motor vehicle Bumper Fender
Moderator
Here's a few pictures of the later style AC bracket.
These required an extended #1 exhaust stud in the head.
* These are hard to find.
The one I had came from a rotted out '78 coupe parts car I had behind my house.
Automotive tire Auto part Machine Motor vehicle Nut
Automotive tire Gas Auto part Plumbing valve Valve
Automotive tire Gas Rim Motor vehicle Automotive exterior
Car Vehicle Motor vehicle Automotive fuel system Automotive design
Pretty sure thats the aftermarket bracket that came in a kit. I've seen them on every model Alfa. 105 series, etc.
The Alfetta parts books only show the bracket that goes across the head. Those are the only ones I saw on factory A/C cars.
Reactions: 1978alfa
