101 - 112 of 112 Posts
Discussion Starter #102
This would have been a lot more interesting in an Alfetta GTV, Better balance and maybe been able to use the Ferrari transaxle.
If you saw the weight difference between engines you will see that this will end up with almost the same weight balance as when it came from the factory.
When are you going to have some Alfa merch?
Discussion Starter #106
You are right I have been totally slack. I do have one of my viewers who reached out and is working on something. I should chase them up and see where they are at with it.
Discussion Starter #109
Yeah, but you would still have the transaxle design with the Alfetta GTV.
The Ferrari transaxle still wouldn't work in the Alfetta. The axles of the Alfetta are at the rear of the trans, where the Ferrari are at the front, so the Ferrari trans would still hang out the back of the car.
Discussion Starter #112
It appears you didn't so much buy an Alfa as a template made out of iron oxide for building one. But very impressive work so far!
Haha. I like that, although I wish I was the only one, but there are so many on here who are worse off than I am, which is a very scary thought!
