I yield my life, and my alfa's life to a higher power, and I admit, my re-built motor weeps oil from a couple places, my re-sealed steering box weeps gear oil from the main upper gasket, my gear box leaks oil from a non-factory drain plug (without a magnet) which is too long and I have to use two oversize width gaskets causing the leak, and my differential is beginning to leak into the passenger side axel... and I do use synthetics throughout the vehicle... but the leaks were there whether dino or synthetics were used, and were worse before the various seals and gaskets were replaced.
There. I said it. And I feel relieved and empowered.
PS My steering box leak was so bad, I could fill up with lube, and find it on the garage floor in the morning! What a mess. With the new lower seal, it found another, slower way to find the garage floor. Gravity is relentless.
