Hello to all.
I've a friend of mine that has a lot of of Giulietta parts, many of them from the Veloce type. Among those parts we found this sump. The numbers point for a TZ sump.
The question is: this parts came from a lot of 1955 and 1956 Giuliettas Veloce lightweight, probably Conrero. As we didn't have any TZ in Portugal, may this sump be from a Conrero? What differences did the Conrero Giuliettas showed?
Thank you for your help.
Keith is correct, You will be able to tell if it is 750 or 101 by the casting numbers. The 750 has a round hole in the front sump bottom to clear the 750 short bottom oil pump, the 101 a square and deeper hole for the longer bottomed 101 pump. It is not TZ.
Thank you for the answers. Big help indeed.
The sump you show, 750 or 101 has value with the included oil pump goose-neck pick-up. There are many BB readers that would be interested.
Hello Gordon, I'm doing a list with photos, ref. numbers and prices. Then I will post it. Thank you once again.
