Hi All,
I'm just rebuilding my original S4 power antenna from scratch and all is going well. However I notice that there is a drain hole at the bottom of the unit.
My logic is like everything else on the S4 that there is a drain tube from everything including the battery tray. I can see that at the base of the power aerial there is a nipple that is quite obviorsly desingned to have a drain tube fitted.
Does anyone here have any idea where this drain hose would be threaded to the outside and underside of the Spider as I cannot imagine that it would be left to drain into the spare wheel well.
Any ideas woul be most welcome.
Thank you - P
Thank you - P
