Hello everyone,
we need your help!
We own a 1969 Alfa Romeo Spider 1750 Iniezione (Spica Injection) that will start but then die. The engine starts almost immediately and goes up to about 1100rpm and then it dies.
Does anyone know what our Problem could be? We have tried almost everything and are out of ideas. This car just won't run.
We have changed all filters, the fuel tank and lines, the coil, spark plugs and our Spica pump has been rebuilt. We set the ignition timing and checked the pump for correct timing. As the engine starts, you can smell that it is getting enough gas (not too much) and the throttle setting has been checked as well.
We tried setting the ignition timing, checked all connections and lines and did everything as written in Wes Ingram's Book and other Alfa Manuals.
Maybe @Roadtrip has any ideas?
Thanks in Advance.
we need your help!
Thanks in Advance.
