1 - 1 of 1 Posts
Dear fellow members,
I have the following two problems with my Alfa Romeo Mito 1.3 JTDm 2011:
1. High Pressure Diesel Injection:
The common rail diesel injector seems to have a small leakage; I suspect one of the seals leaking. Do you agree? I have no spilling on my parking spot. Only the injector itself and the pipes below it are covered in smear.
I am about to buy a Star repair gasket kit, to see whether it stops the leaking. What do you think?
2. DPF warning:
A couple of weeks ago the DPF warning-light came on (P2453 | Diesel Particulate Filter Pressure Sensor A). I replaced the following parts:
  1. the Differential Pressure Sensor (and relearned it in the ECU);
  2. the upper two DPF vacuum tubes (6mm & 8mm);
  3. the MAP sensor;
  4. the MAF sensor;
  5. Blanked the EGR valve (it has been disabled in the ECU).
After resetting the warning, it keeps coming back. Not right away, but after having driven multiple journeys. I still have to replace the bottom two vacuum tubes. However, is it possible that I get this warning because of the diesel injector leaking a small bit? AlfaOBD gives me the extract below upon hitting the warning What do you think?
1 - 1 of 1 Posts
