1 - 5 of 5 Posts
Hello I am new to the forum
I need to replace the starter motor on my car
is it done easily from underneath of the car or from the top if I remove the air filter housing
could you please direct me to the right link
Thank you
The higher torque of the later starters require a support bolt that connects the end of the starter to the motor mount. Removing and installing this can be a real pain, but there have been instances of fractured bell housings from ignoring this step. A good alternative is to use one of the small gear drive starters as used on the later Spiders, or purchased from one of the Alfa parts suppliers. These are much easier to install, don't require the support bolt, and crank much faster.
1 - 5 of 5 Posts
