1 - 9 of 9 Posts
Same may know I had beed trying to determine the difference (if any) between AR-303 Rosso Corso and AR-501 Rosso Classico.
PPG uses different codes for these, perhaps indicating they are different. PPG calls AR-501 > PPG-71718. And AR303 > PPG-71297.
I have finally found color chips of both colors and a bunch of other data. I found only one paint chip for AR-303, but I found several for AR-501. Both of these chips were very similar, essentially the same! Not surprisingly there were small (insignificant to me) differences among the AR-501 paint chips from different years. I noticed that the formulations for the color also changed slightly from one year to the next in at least the Glasso paint book. Unfortunately, there was no formulation given for 303 so I could not completely compare it to 501, but again, it looked very similar, the same to me.
I also found a Dupont book containing both colors. The dupont book lists the same code for both 303 and 501! So this is more evidence the colors are the same.
You may download a boatload of colorcharts here from my website, if you like. It includes many of the other Alfa colors as well.
http://www.liebold.com/AR/ARpaint.html
One pic below shows the AR 303 and 501 chips side by side, both from Glasso. The other pic shows the Glasso AR303 chip behind another unknown company's AR501 chip. The unknown company chip has a round hole it so the AR303 shows through.
Both pics show the color being very similar. Obviously the colors are distorted in the photos, but you can see the similarity. I now consider the colors the same.
Carl
Discussion Starter #2
why it matters...
I meant to say why I cared about all this... Most of the info I have show AR-501 red starting around the late 60s. If this is true, to paint your early 60s car the proper red, it might not be the right color. But since it appears the earlier AR 303 red is essentially the same color, my concern didn't matter. For an early sixties car it looks to me you can paint it AR-501 color, and call it AR-303 Rosso Corso if you want!
C
Hi Carl,
Excellent research! Thank you for putting the information together and sharing it with us.
I included a reference to your threads in the 1972 Alfa Romeo Color Chart.
Ruedi
As I said in a previous post, a friend had his 2600 Spider repainted last year in AR-303 ("Alfa Racing Red" per the 1962 factory bulletin) mixed up using the Ditzler code by a large paint supply store here in Phoenix. To my eye, the color is quite different from all the AR-501 cars I have seen. It appears more bluish and darker. I saw the car this weekend but did not have my digital camera with me. Again, there is no guarantee that the color is true to the original. As you suggest, the only way to know for sure it to find a car with original paint and look at some hidden, unfaded area to be sure.
Arno Leskinen
AROC National Concours Chair
102
115
116
Since we already have a thread on Alfa red paints, I also have a question. My code sticker says Duco Montecatini Rosso 95-C-9608. Can someone tell me what this is/or means? :confused: :eek:
vintageveloce said:
Look here:
The numbering system there and on the other charts I see don't match any of my numbers and that is why I'm confused. Do I convert them and how? Is ther a conversion chart?
"Duco" is the manufacturer (or the product line), "Rosso Montecatini" is the name Alfa Romeo gave this paint color, and the string "95-C-9608" refers to the paint code of the paint manufacturer.
According to the information I have in my database, "Rosso Montecatini" refers to Alfa Romeo paint code "AR-504" and is available under DuPont code number C-9068.
Please note the reversal of the numbers "6" and "0" in the Duco and DuPont codes. I don't know which one is correct. There could be a typo in my database. Possibly both are correct. Could you double check if the number you posted is correct, please?
Cheers,
Ruedi
Reudi, thanks ever so much for catching my error! :eek: You are correct it is 95-C-9068!
Next question would be, are these paints still availible and I would ask for Dupount C-9068 or?
1 - 9 of 9 Posts
