61 - 80 of 89 Posts
Discussion Starter #64
Spica specific gaskets. The string and tags show the gaskets for Spica cars.
1626274
Discussion Starter #65 (Edited)
Spica Idle Air Tower Gasket. The small
1626439
gasket on the bottom of the photo. For 1971 and on Spica.
Discussion Starter #66
Bosch relay for Spica Alfa
1626901
1969 and on. 105.71.65.092.00 emergency flasher for S1, S2 USA 1750 GTV, likely Spider, possibly 2000 as well.
1626902
Discussion Starter #68
The Bosch relay in the top photo is sold. It is different than the identical shaped Bosch relay in the second photo. So I don't have a 0 332 005 011 anymore.
Discussion Starter #69
I have sold the RF bumper, the Spider rubber headlight rings, and the 5 Spica specific gaskets.
Discussion Starter #70
Some GT parts that I want to sell as they don't fit my S2 Euro 1750 GTV.
2 rear bumpers 69 and older GTV or 70 and older GT Jr.
2 sets of Black door cards and cards for rear seat area, 69 GTV or 70 Jr. and older
Rear parcel shelf black 69 GTV or 70 Jr and older
Driver's seat S1 Euro 1750 GTV LHD non-headrest type, frame, and parts
Discussion Starter #71
I want to sell some Alfa parts that I probably won't need. I will try to provide a partial list, add to it as required, and supply photos if requested. I will update this list regularly. I still have parts from a 67 GT Junior that I parted out years ago, plus a few Spider & Berlina parts and lots of GTV parts, mostly from 1750 GTVs. Some 1600 GTV & 2000 GTV parts. Here is a partial list of some "NEW" and mostly used parts.
Romablok hose clamps
Stinger pipe to replace rear muffler includes a stainless tip,
can fit Spiders, GTs, Giulias, or Berlinas
Front exhaust for S2 1750 and 2000 GTV
Middle exhaust section
Exhaust manifolds for 1600-1750-2000 engines
5 - 40mm carb rubbers
Gas pedals and throttle linkage.
Throttle linkage rods 12'', 4'',& other lengths
2 - 1750/2000 GTV & Smooth nose GTJr. radiators
Bosch distributors & rotors & caps
Marelli distributor & rotor & cap
Hood & trunk release components
GT hood, smooth nose
Passenger door from S1 1750 GTV or earlier GT or GTJr.
Aluminum front spring spacers 7 & 10mm
Front lower A-arms, upper arm, castor arm
Rear trailing arms
T bar, and conical bushings
Shock absorbers
front anti-sway bars
rear anti-sway bar for Spider
Interior door cards and rear side panels 1969 GT and older in excellent black vinyl
Door handles exterior & interior, window winders, door hinges, etc...
1750 GTV console, and gauges
Speedo, Tach, clock, fuel, temp
C pillar badges for 1750 & 2000
GT chrome and stainless parts
Rear stainless steel bumpers series 1 1750 GTV and older GTs & GTJrs.
Rear stainless steel bumper series 2 1750 and newer GTs & GTJrs.
Front parking lights S2 Euro 1750 GTV
Rear tail lights and lenses small GT Euro and USA 1750 S1
Glass for side and rear windows on GT
1 rear screen no defroster wires, 5 side rear vent glass
2 front door vent glass
Engine gaskets and seals
Spica parts and gaskets
Spica & Euro front engine covers 1750
Aluminum wheel spacers 2 of each size, 6.3mm, 4.6mm
Water pump for early alternator Alfas, 2 outlet hose fittings 68-72
Water pump for 1300 & 1600 cars 101 or 105 with generator 2 outlet
Rad overflow plastic bottle
1750, 1600, 1300 steel wheels 14''x 5.5'' 38mm offset w hubcap bumps
2 Michelin XAS 165 HR 14 excellent tread and condition
Cam Cover for 1968-1977
Camshafts, Liners, Pistons, Rods, Oil Filters
Clutch master cylinders floor mounted
Brake Master cylinders, floor mount, and hanging pedals
"NEW" hydraulic brake lite switches in the box "NEW"
Floor pedals
"NEW" rear brake pads "NEW"
used brake pads for GTJr. and other 105 cars
Calipers front & rear
GTV 1750 rear seat vinyl, series 2, black fair condition
GTV 1750 front seat, series 1, euro drivers no headrest type, left-hand drive
"NEW" Fiamm horn x 1 "NEW"
Bosch horns x 2
Mixo horn x 1
1750 engines, transmissions, blocks and heads
Starter and Solinoid
Interior mirror parts
Washer Bag Cap and parts
Hand brake levers, handles, and parts.
Interior lights and trim parts
brochure 1965 Sprint GT, Giulia 1600 Spider & Veloce, TI, SS, TZ, 2600 Sprint & Spider
sales brochure for 1750 Berlina
sales brochure for Giulia Sprint GT
sales brochures for Giulia Spider
sales brochure for Sprint 1300
sales brochure for 1992 Spider & 164
many multi-page promotional materials
1750 round tail Duetto road test Track & Traffic Magazine
80s Spider brochure
68 GTV road test Track & Traffic magazine
many Alfa books & workshop manuals
I have many more parts not listed.
Discussion Starter #73 (Edited)
Updated
Stainless tips for tailpipe 2.25'' and 2'' dia,
"NEW" center to rear section exhaust joint donuts "NEW"
Exhaust manifold for 1600-1750-2000 engines for cyl 2 & 3 only
Carb throttle linkage on the firewall.
2 - 1750-2000 GTV & Smooth nose GTJr. radiators
Rear trailing arms
Shock absorbers
Front anti-sway bar, front springs
Rear anti-sway bar for Spider
Console gauges
Speedo, Tach, clock, fuel, water temp
"NEW" Engine gaskets and seals "NEW"
Spica parts, rear fuel pump bracket, fuel line clips
Aluminum wheel spacers 2 of each size, 6.35mm, 4.76mm
Water pumps for early alternator Alfas, 2 outlet hose fittings 68-72
Rad overflow plastic bottle, bracket, clip, and caps
1300, 1600, 1750 steel wheels 14''x 5.5'' 38mm offset w hubcap bumps
Motor mounts, transmission mounts, Exhaust brackets
Clutch master cylinders, hanging pedal
Brake Master cylinders, hanging pedals, 69 USA floor pedal internals
Floor pedals
Used brake pads for GTJr. and other 105 cars
brake booster diaphragm for floor pedals
Bosch horns x 2
Mixo horn x 1
Starters and Solenoids
Hand brake levers, handles, cables, shoes, and parts.
sales brochure for GTV-6
80s Spider brochure
Discussion Starter #76
I have a bunch of Romablok hose clamps. Sizes 54 x 2, 42 x 2, 33, 26, 19 x 4, 17 x 3, 14. All in good condition. Also a few more I cant read the sizes on.
Discussion Starter #77
Clutch slave cylinders, one is marked ATE others no markings. I have all the boots, rods, pistons, seals, and clips.
Discussion Starter #79
Clutch slave cylinders. Each shot is rotated 90 degrees. Single slave last pic is ATE. Which was top left in other pics.
Discussion Starter #80
Ate brake master floor pedal single cct. Clutch floor MCs. The rest of the parts that go with floor pedals and slave cyls.
61 - 80 of 89 Posts
