201 - 220 of 222 Posts
On the exhaust fume problem, yes of course all the connections have to be leak tight, but also replace the hood seal and the hatch seal at the rear. That's how we solved that issue with my son's car.
If the underhood seals are in good condition and in place, run the hvac fan all the time, as that pulls in clean air from the base of the windshield, lightly pressurizing the inside. Do not drive with a door window partly open, as that can create a partial vacuum inside, potentially pulling air from the rear. Therefore, as mentioned above by alfaloco, make sure the seals around the rear lid are in good good/intact.
Really beautiful looking car. Just great work.
I've found that if I drive with one window (driver or passenger side) partially open I notice an exhaust smell in the cabin. But if I drive with both windows partially open (or more) then no exhaust smell.
Discussion Starter #204
Started doing just that ...driving with both windows partially open. The car is still tappetty but loosening. Still stumbles at an indicated 4000 rpm. and on pushing the throttle. The AFM for the BMW from Cardone arrives....635 csi Ljetronic AFM... and guess what it has 5 pins....God it had to happen did it not.
So another one ordered ...lets hope its the correct one when it comes. Am also in the process of getting a spare one I have refurbished by Vickauto. I WILL WIN THIS.
Fix the tappet noise. If exhaust, just a simple screw adjustment!
It would be really awesome to post a "before" and "after" picture of this car on one post. The change is really amazing. When I first started reading I thought "he will never make it - that is too far gone". Even when I saw the GTV6 parts arrive I thought " a junk car to fix a junk car".
But the results are truly amazing. Bravo on your determination. Sure there are details to finish - its an Alfa - but you are able to drive it now.
When I had my GTV6...I 'discoverd' the following: When I had a non-standard exhaust fitted, I picked up two new problems
1) A nasty flat spot/stumble at 3750rpm, and
2) Exhaust fume smells unless the cabin blower was on.
Seem familiar?
My theory on 1 was the two OEM front stub resonators are tuned exactly to 3750rpm, and if you put a custom system on the injection will get all confused, and over-fuel, as it expects the engine to breath wildly at this RPM.
My theory on 2 is that the tail pipe needs to be centralised, or the exaust gets pulled into the wake vortex and into the rear cabin vents.
My theories held up when I got 3.0 75, I cured a bad flat spot at the magic 3750 by fitting standard front resonators in place of the straight pipes that were fitted. It is not very scientific, but it seemed to hold true on these two occassions. Hope that helps.
Discussion Starter #208
Exhaust etc
Seem familiar?
I have a CSC exhaust system fitted with an ANSA exhaust. Just got a new/ refurbished BMW AFM... will put that on and see .. and if that fails. The exhaust fumes... well sorting out the seals first and then follow your advice if that fails.
Cheers
Discussion Starter #209
the petrol smell
the petrol smell has been traced to two things.....the fuel tank in the boot leaks and the holes in the fornt bulkhead havent been closed off.....the inetrior fills with the air form the engine compartment with the additional smell form the boot. Cant blame the workshop as I just the car out unfinished to check the engine drive train and mechanicals. Also to make a check list of things that need to be fixed.
Tried the 633 csi AFM....something happened that I have found strange. The car started and revved nicely... but did not idle so adjusted the idle on the new AFM and the car then stopped revving properly and did not pull. Brought back old AFM and it was back to driving OK on part throttle but with the stumble at 4000 rpm or so.
I am now looking for a L jetronic BMW 633 ECU.
John Kartalamakis mentions in his book that the 635 CSi ecu and AFM work and are plug and play.. well almost ... but these are Motronic and not L Jetronic whereas all GTV6s were L Jetronic so what is he talking about????
Some pics on our latest trip to the Khyber Pass and the Afghan border.. Torkham and the Michni Frontier Corps forward post on the Afghan border.
I really appreciate your sharing these photos. Understand that Khyber Pass and the Afghan border have a completely different connotation to this isolated American guy. It is great to put some different images into my mind. Especially ones that I can relate to.
Looks like it was a great time out.
Mark
I think you should get the correct AFM for the GTV6. You should contact sources in Europe like SAVALI and OKP engineering. There is always some surplus.
With regards to the AFM for the 635 CSI, mentioned by Jim Kartamalakis, I think he mentioned the first model which had L-Jet. in 1980 the model changed to Motronic, so after that would not fit. Look for model E24, engine M90.
Some References:
https://en.wikipedia.org/wiki/BMW_M88#M90
https://en.wikipedia.org/wiki/BMW_6_Series_(E24)
G.
Discussion Starter #212
164 heads on a Milano/75 3.0 litre block
As you will have gathered by 3.0 lire engine...the left hand head....drivers side on US cars and passengers on RHD... wasnt done up properly by the machinist. I am now being offered 164 heads....
A small question... will the 164 12 valve heads fit onto the 3.0litre block from a 75/ Milano????? without modifications. Dont want to go through the expense of getting the heads all the way across several ponds to kick myself later
Discussion Starter #213
pics of 164 heads on offer
pics of heads... will they fit on the 3.0 block form a milano/75 and what mods if any I will have to make...obviously the distrbutor will have to be blanked off...but other things???
Yes I am quite sure the 164 heads will fit on the 75 3L engine. Have not tried that, however the 164 engine is a development of the 75 engine by turning it 90 degrees to fit a front wheel drive engine. The 164 crank is 4mm Shorter than the 75 engine, but I think that does not bear on the heads. With regards to the distributor connection on the 164; the whole sub unit can be removed and the blanking plate from the 75 engine can be installed at that posistion, no problem.
So I say compare the heads mating surfaces, I think they are the same and then put the 164 head on the 75 Block to see if the holes mate properly with the head studs.
On the other hand I have tried to put a 2,5l GTV6 2,5 head on the 164 3L Block. In that case there was some overly resistance in gliding down the head studs. So that was not a proper fit. A test done just to see if it would fit.
However in the case of 3L 164 heads on the 75 Block I would expect a better result, but you need to see!
Yes the 164 heads will fit on the 3.0 liter 75 block. I am in the process of building an engine using those components currently.
Discussion Starter #216
the GTV6 photoshoot
The car isnt perect yet...problems with the head persist with a noisy left sided head where the valves arent adjusted due to incorrect size shims. So its tappety and noisy. The second gear pops out and the gear lever selection inspite of the isostatic lingae is completely hit and miss..........rowing in treacle. The ocsmetics are being slowly completed.
Sounds like a normal Alfa! The list for the daily driver Milano reads:
- Leaking left rear caliper (add brake fluid every third day)
- Leaves in the heater blower rattling - again
- Seat webbing broken again. Sinking down to the floor
- Passenger door handle needs to be fixed and reattached.
- Lifter noise from the RH head that comes and goes
But still give me smiles every day as I drive it.
Your car looks fantastic! when I first saw the thread and the car(s) that you were working with, I never thought it would get to this level of execution. very nice job and amazing determination!
Spectacular looking car. What an inspiration. This is truly a Phoenix.
I drive mine daily, and it has a running list of "what needs fixing now." Building the car is one thing, developing it is an entirely new and different job. I'm sure, given your efforts and results to date, you'll have this car the way you want it in a reasonable time.
Bob
