I don't know anyone who has tried it. My gut feeling is that it wouldn't be too bad a these swaps go.
You would also have to put in the Alfa transmission and rear end, because the Fiat units are pretty marginal above 140hp. A lot of the high powered Fiat 124s have Fiat 131 transmissions, and Ford 8" rear ends.
The Fiat twin cam engine is actually really good. I don't think I would replace it with an Alfa engine. The Alfa engine is better, but not that much better.
Greg,
Silicone Hose Kits
OKINJECTORS.COM
Unfortunatly we don't have those great engines in the US. But I do have an extra TS and an extra 124 body........just thinking!
Not trying to sound negative, but no engine swap is easy. Two hitches I can see putting an Alfa twinspark into a Fiat 124:
- The 124 has its intake on the left and exhaust on the right. The Alfa is the reverse. So a whole new exhaust system would need to be engineered.
- The twinspark is pretty tall, due to the valve angle. I know it is tough fitting one under an Alfa spider hood, and I would expect the same problems in a Fiat spider.
And that's the bottom line for most engine swaps: Put half the time and money that an engine swap requires into making your Fiat driveline faster/better/cleaner and you will be way ahead.
