1 - 13 of 13 Posts
More Alfa 6C parts available:
Cylinder head with matching cam caps, camshafts, valves, springs etc.
Column shift gear box.
Bosch distributor
Carburettor with intake manifold
6 NOS Dunlop 5.25 5.50 / 18 tires
Set of 4 knock off center caps (2 destro and 2 sinestro)
[email protected]
Hallo!
We are rebuilding the engine 6C 2500 Sport. Engine manufacturing in 1939. Interested in any literature on the repair. Scheme. Drawings. Data.
We need to know the color of the following parts:
1. color of the valve covers
2. color of intake and exhaust manifold
3. color of cylinder block
4. cylinder head
5. color of bolts, nuts, washers on the engine
6. water pump
7. oil filler neck
8. oil pressure tube, which is located on the cylinder block
9. starter and generator
And we also need to know the torque of the bolts on the engine. And what sequence of installing a chain mechanism for timing?
Also we would like to buy the following parts:
1. oil filter
2. cylinder head gasket
3. gasket of the valve covers
4. water pump gasket
5. spark plug (6 pieces)
6. timer
Please help.
Kind regards, Oleg Nagorny.
AnNa moderna LTD, city of Voronezh, Russia.
The NOS Dunlop tires have been sold.
6c 2300 cylinder head, Bosch distibutor and the intake manifold still available.
Speedometer drive 6с 2500
Hi! Can you confirm this is the speedometer drive? It is very difficult to find it ... can anyone give advice? Requires Speedometer drive (which is inserted into the gearbox) and the speedometer cable....
1 - 13 of 13 Posts
