Hi Active:
Here are the Autocad files for the 1.7 16v head gasket. There maybe others who can use these files as well. The bore hole size in the gasket is set for 88 mm dia. which should be OK for a standard bore engine. On my racing engines the bore size is 89mm dia. and i cut copper gaskets with a 89.5mm dia. bore.
For your info the copper gasket is 1.2mm thick.
It seems that the files types are not supported on the BB, if anyone needs these files I can send them direct.
Regards..Bob
