Hi Herve,
You will want to use the lower pressure version. I believe it is Facet p/n 477060E. I recently installed one of these on a BMW 2002 and it seems to work perfectly. I measured the output pressure at just under 4 psi, which is the ideal pressure for the DCOE carbs. My experience with Solex carbs indicates that the lower the pressure the better, due to poor sealing of the inlet needle/seats, which results in excess fuel dribbling in the manifold and elsewhere. This pump is available from many sources. I walked into my local Napa Auto Parts and walked out with one in my hand (Napa p/n 610-1075, you can look this up on Napa's web site). I paid a bit of a premium there but I was pressed for time. Napa also has the internal filter replacement kits and soft mounts available on special order. I do not know if the filter fits the vintage Bendix pumps. It might since these are a direct descendant.
Steve
