Push hard and live
What info are you seeking? The rubber from Cicognani is fine. The trick is the length to cut it.
Hi,
I got rubbers from Cicognani but these are for 2600 spider with small vent glas and stainless frame with thickness of +/- 12mm and glas of 2000 spider is only 6mm
rgds Franco
doorglas rubber
Hi All
this is a picture I found but looks not original ?
are the rubbers from giulietta -giulia spider the same ?
rgds Franco
Push hard and live
Franco,
I posted in your other thread on this subject. We cannot see the cross section of your rubber, but it is apparent that they are installed with the inside on the outside. Of course they look wrong in this situation. It appears they have been trimmed for length to suit their current positions, which means they are probably now too short to work when swapped to the other side.
