301 - 320 of 380 Posts
On the sunroof, pop the light unit out of the overhead consul. There's 2 hidden tabs on the rear right side and forward left. You'll see the motor for the sunroof and on the end of the shaft a slot for a screw driver that can be used to manually close it.
Hi all, trying to tension my alternator belt, but I can't seem to get the alternator to move up to tension it. I have loosened the 3 securing screws, except the bottom one closest to the belt seems to not be backing out/getting loose. I've tried a pry bar on a few different spots and alternator stays right in place. It seems that the whole bracket has to move with the alternator if I am looking at it correctly. Any advice?
Discussion Starter #303
Bottom fourth bolt has a 13mm nut on other end near bottom of dip stick housing. Hold nut with wrench/socket and loosen head of bolt.
Thanks Steve, I figured that there was something on the other side, but kind of brushed it off thinking "Alfa wouldn't put a bolt like that right beside the headers." I was wrong!
Well guys I'm back at it again. This time trying to figure out what feels like an intermittent misfiring issue. I'm going to check the plugs and wires first, but do you all have any recommendations for stuff to check?
Discussion Starter #306
Plugs condition proper gap 0.025", wires 2.5k ohms resistance, dizzy cap for cracks/corroded terminals and good spring loaded carbon button and rotor resistance 1k, plus coil wire resistance 1.1K and coil tower for corrosion.
Check injector connectors/ terminal pins for corrosion, too.
Discussion Starter #307 (Edited)
Discussion Starter #308
Discussion Starter #309 (Edited)
Alfa 12v and 24v V6 timing belt tensioner bearing info
This bearing info is for the Alfa 12v V6 Alfa engine with oil fed timing belt tensioner and the 24v V6 engine timing belt tensioner bearing.
The bearing outside diameter is 58.5 mm, width is 30 mm and inside diameter is 35 mm.
Some possible manufacturer's part numbers for just the bearing with no center hub are:
SKF 633254
FAG 536392
HT 633254
The Alfa Romeo part numbers for bearing with center hub are:
60513022 bearing and center hub for Alfa 12v GTV6, 75, 155, 164, RZ and SZ for oil fed tensioners 60513020 or 60808222
60580235 bearing and center hub for 24v V6 164 only for 60584475 tensioner (sealed unit)
ALFA ROMEO 60580235 bearing with 24v hub Bearing on hub issame as one used on oil fed tensioner for 12v V6 so bearing can be removed and pressed onto 12v oil fed hub.
AUTOKIT 03.80144
BREDA LORETT CR3423
BREDA LORETT TDI3423
BREDA LORETT CR 3423
DAYCO ATB2574
LANCIA 60580235
RPK RPK0091641
SK SK0080541
SPIDAN 70275
TREVI AUTOMOTIVE TD1582
OPTIMAL 0-N1090 / 0N1090
Sadly the alfa digest domain seems to have gone away. But if you Google wayback machine and copy the digest links into it then you can find the referenced documents. Just had to do this to do a refresher on pulling cel codes.
Discussion Starter #311
How unlucky am I? I have my L listed for sale and the other day I went to start it up and I got a nice steady plume of white smoke for a bit. Smoke didn't smell like antifreeze, nor did it really smell like oil. Anyways, it was cold and rainy but I think I've seen the valve stem seals rear their ugly head. I can't sell the car under the condition that I have it listed in because I need to figure out what the hell caused that smoke. I'll start her up tomorrow and see if it's a consistent cold start problem.
Discussion Starter #313 (Edited)
Fuel hoses and check valves for 164 info
I just got in some stuff I ordered in for spares.
1. Gates 27335 5/16" (8mm) SAE30R9 rated fuel injection system hose.
2. Gates 27093 5/16" (8mm) SAE30R10 rated FI submersible hose.
3. Dorman 800-195 externally mounted fuel system in line check valve.
4. Bosch fuel pump check valve with copper washers and cap many part numbers but one number 1 583 386 016. Many more numbers listed on ebay for Audi, Ferrari, Mercedes, Porsche and VW for same check valve.
Discussion Starter #314
Alfa 164 Bosch in tank fuel pump info
Alfa 164 Bosch in tank fuel pump with pre-filter screen on bottom.
This is a 0 580 464 990 pump and it comes with inline check valve already mounted on it but 1 583 386 016 is one of many p/n's for just the check valve. It is used on many Audi, Ferrari, Mercedes, Porsche and VW models.
Discussion Starter #315
Discussion Starter #316
164 12v V6 ignition system resistance readings
1. coil primary terminals 1 to 15 0.7 to .8 kΩ
2. coil secondary 5.4 to 6.6 kΩ coil tower to 1 or 15 terminals
3 coil wire 1 kΩ
4. rotor 1.1 kΩ
5. plug wire resistors 2.5 kΩ
Discussion Starter #317 (Edited)
164 12v distributor seals
Correct shaft seal and oring for 164 12v distributor
00605005160000 dist shaft seal $15.01
00605005120000 dist body seal $3.51
Sizes: http://www.alfabb.com/bb/forums/7343641-post135.html
Believe it or not I found a new 60500516 shaft seal in the 93L under the driver's seat month ago at Pick-N=Pull, but no part number on the cardboard sealer pack.
I found my spare dizzy parts this morning with part numbers on package boards.
I have the 60500512 dizzy body seals, too.
As you can see shaft seal OD is about 28mm (1 18") and o-ring about 40mm (1 13/16").
Prices are from ARI-Orlando but they don't have shaft seal in stock.
Discussion Starter #318 (Edited)
Dayco ATB2521 and Alfa 60588421 V6 Mechanical Tensioner
Seems like First Tier Supplier for the Alfa V6 Busso engine mechanical tensioner is Dayco.
Here is one of each side by each! DAYCO - Move Forward. Always.?
Dayco ATB2521 (H60588421) Made in Taiwan aka AR 60588421 Made in Canada.
I got one today from Latvia ebay seller today.
Discussion Starter #320
