Note: 24v steel tank models very similiar as is Euro models with plastic tank. See Alfa parts CD or DVD for differences.
As you all may know by now Non-Quik Silver Rescue project has taken on a life of its own and once a car has set up with a tank of gas for over four years neither the gas or tank are fit for the engine to consume. Not to mention the fuel pump won't work.
I ended up pumping out to foul gas, pulling sick pump and getting sick myself at the sight inside the tank.
Spare parts to the rescue as I had a tank I was holding for Old Nero rescue project, but she is way down in the que. We had recently picked up a pump assembly from a Pick-N-Pull 164 so all I had to do was freshen up tank and pump and test them together on the garage floor like I did engine.
Use stato-seals on tank cover bolts frome Home Depot: http://www.homedepot.com/p/Everbilt-10-Galvanized-Bonded-Sealing-Washer-4-Piece-806718/204276436
NOTE/Caution There is/was only one hole of the 8 in top of pump mount (rubber bushing) for soda straw that is drilled all the way through. Hopefully you pick the right one.
Here are some show and tell pictures:
