91 164S. Blinking airbag light. Did the diagnostics. Threw codes:
16 - Failure of forward left hand sensor
35 - Open Circuit
36 - Faulty Squib
Checked the connection of the sensor and cleaned and reseated the bolts to ensure a good ground.
Tried to clear codes, but would not clear. All three still there.
Question.
1. Can I switch the right sensor to the left side to try and see if it's truly a bad sensor, or is it in the wiring. Are the left and right interchangable? Is there anyway to test the sensor with specialized test equipment?
2. I reviewed Steve's previous thread on the subject and it sounds to me like the Open Circuit and Faulty Squib could be a bad clockspring connection in the steering wheel, like he had.
If I remove the airbag squib and the top cover of the steering column, can I test the continuity of the clockspring without removing the steering wheel? Is there any special procedure to this (other than making sure the battery is disconnected, of course).
Any thoughts or guidance from the 164 experts out there?
I'm assuming I'd start my search for spares at APE, but is anybody out there breaking a 164 for parts?
35 - Open Circuit
36 - Faulty Squib
Question.
