the plug is the same as my 75
Motronic plug not the same as L-Jet (4-PIN vs 7-PIN)
Duk had mentioned it before, you can swap a couple/three parts and use the bigger housing. I have a thread on this somewhere. Without performance cams, raised RPM threshold, and headwork, you will sacrifice every day drivability for a couple horse on paper above 5ooo rpm.
I'd say focus on making it run purrfect with what you have. You can't build a cathedral to lofty heights without first laying a strong foundation my friend.
If the plug is indeed the same, then you have a twin-spark with Motronic already - not L-Jet. Give it a shot and see how it goes. I forget they produced (offered) the 75 in Europe and elsewhere for a few years later than in NA.
