my 75 with a bad idle
M maytereh · Registered Joined Apr 27, 2007 · 4 Posts Discussion Starter • #1 • Oct 2, 2007 my 75 with a bad idle
RAGs · Registered Joined May 25, 2007 · 487 Posts #2 • Oct 3, 2007 Ah ... ...some more details of the problem might be helpful. Was this a recent change? Any engine mods? Timimg and belt fine?
M Meimaridis · Registered Joined Aug 19, 2005 · 26 Posts #4 • Oct 20, 2007 Let me guess Hickups of idling and maybe some cutoffs during drive? First check if the tubing after the AFM (if its connected correctly - no leaks or holes) If this is ok... Borrow another sensor from a same car and plug it in. If the car works fine you got yourself a naughty AFM I know that they're a bit expensive as new (700 euros-1000 dollars) but there might be someone who knows about remanufacturing those **** things (Injection Correction UK - Remanufacturing automotive engine management systems (ECU) and air flow meters and BBA reman. ABS, ecu's, throttle bodies, air mass meters, and catalytic converters) and offer 1 or 2 years gurantee. Haven't tried anyone yet (has anyone?) but willing to do in the future as i have 3 AFMs out of order
