Hi Chris and all,
According to the early 105.02 catalog 993 from 6/1964, the strut had Alfa
# 105.02.08.055.00. it was replaced afterwards for
# 105.02.08.055.01, that also was listed for the 1600 Giulia Super and TI Super.
The date of change is unknown to me but it was announced in a 9/1967 addition to that early catalog.
The difference between those two 105.02 struts, that was mentioned in that same addition, was about the bushing indeed, as the bolt for fixing the bushing in the motor mount changed from 6 mm to 10 mm. At least the number of the motor mount was changed too.
Comparing the drawing of the strut in post # 1 with the one in the picture here below, taken from the 993 catalog, one could suppose indeed, like
quadirfoglio suggested before, that the early bushing was smaller. Maybe someone else can confirm that ?
Chris, maybe you can check your (inlet side) motor mount for having a hole of 6 mm or 10 mm where the strut bolt should pass.
Secondly, those early struts ( see part at the left here below) didn't have the nuts yet welded at the top of the 'T' section like later struts ( part at the right)
You better check whether your air intake casing has two studs or two holes. Should be like the one on the picture here below I think. That could be important for mounting the strut on the air intake without problems.
I measured the overall lenght of the 105.02.08.055.01 strut as you can see below, it was 36,3 mm.
Or 34,3 mm, measured from the top to the center point of the bushing .
Fwiw, you can see here below that the # 105.02.08.055.01 strut was not curved.
I hope this info is helpfull to you.
Rgds,
Thierry
