Sensor in pic #2 can go along with it's harness.
It controls the aux fan, (which I presume you're dumping), in the event of overheat.
Relays in pic #3 can also go.
One controls the aux fan via the sensor in #2 and the other turns it on with the AC controls in the console.
The heavy wires in pic #4 on the junction block need to stay as they receive and distribute power directly from the battery via the starter motor connection and service the main fuse panel in the cabin along with other items that get full on battery service.
Unless you can chase one specifically to the AC system somewhere, I'd not mess with them.
The small wire w/blade fuse on the junction block in pic #4 services the AC compressor and can be eliminated.
IIRC, the green wire can go too, but can't quite remember specifically enough to be positive about it.
(it might go to the 'generat' light actually. I'll try to confirm via the diagram I have here unless someone else jumps in with the correct answer beforehand)
EDIT
Confirmed: small green on alternator junction block in pic #4 goes to the 'generat' warning lamp in the tachometer.
Leave it alone.
EDIT
Leave it alone.
